iceage
in the north
how do i know what injectors i have, looking to upgrade to high proformace thank you.
atk
Moderator
simcoe, ontario, canada
is this in regards to your other post....`injectors`? or do you want to know if what you have now is OEM(Ford)?
have you had your valve cover off yet? if you have, what colour was the top off the injectors, black or white?
iceage
in the north
no havent the valve covers off it is at the ford dealer right now they are saying that i might have 3 injectors down 2 for sure they are saying that a stock injector is $850.00 for one so iam looking in to replacing them all with something a little better,when odering injectors there are 2 types of injectors for an 04 there is just the 04 and there is 04 1/2 tiring to find out which ones fit my truck.thanks atk
I just had Ford replace injector #5 on my truck and they charged me $285 for the injector. I suspect it is rebuilt, but I am not sure.
atk
Moderator
850.00 for one injector....:eek:....i replaced 4 injectors this past summer, they costed me 400.00 Cdn for one. i would be going to a different dealer. anyway, i would call a different dealer, give them your vin# and they should be able to tell you which injectors your truck take`s. then you will know what to order, if you go aftermarket....hope this helps....
here is a web-site you can try....Accurate Diesel.com....some good info there on injectors
atk
Moderator
that is a much better price then 850.00....anyway, all the Ford 6.0l injectors are remanufactured.
