Help Needed 5R110 Flush
Alexandria, Virginia
So far I have read through about a Brazillan posts trying to find exact info on doing a full flush on the 5R110. Does anyone have a lead on the directions to do this? Any tips or notes? Mine is acting up and I want to do the flush before I do anything else.
I don't need any links for the 4R100 - there are a million or so posts on that - just for the 5R110.
Thanks,
Ron
keanoknick
Big Stroker
Cowtown TEXAS
Sorry I'm of no help with this issue, but thought I would suggest looking for an American post, it might make more sense in English than Portugese. :tounge
:sorry I couldn't help myself :sorry
ponyexpress94
Diesel Power Junkie
Maryland
I have read about the flush procedure in my 2003 Ford shop manual and the 5R110 trans fluid flush as ford expects it to be done requires a machine that they have at their dealerships. In your owners manual under the service interval listings for 35,000 miles (I just hit this mileage so it's fresh in my memory) the owner's manual says to drain the transmission pan and change the EXTERNAL fluid filter which on my truck was inside the right frame rail forward of the front axle and shaped like a small vertical can attached to the trans cooler lines. As the owner's manual describes it (and the shop manual confirms it) you will only drain out approximately 7.5 quarts. The trans holds 18 quarts so you don't even drain half of the fluid. Change the external filter, replace the pan drain plug, put 6 quarts down the dipstick tube, start the truck and let it come up to temp. Once up to temp, add the trans fluid in small increments (1/2 quart or smaller) until the fluid level comes up to the proper HOT operating range on the dipstick as described in the owner's manual under the Transmission Fluid - Checking and Adding section. Even though I only drained less than half the fluid, I know for a fact the transmission was shifting better than before the fluid change and it was shifting great to start with. Additionally, if I recall, the owner's manual doesn't call for a complete flush of the trans and torque converter until 60,000 miles. Hope this is helpful...
Obviously, if you feel more comfortable doing the full blown flush, by all means do so but I don't know of a way to thoroughly flush without the machine that is listed in the Shop Manual. By the way I used the Motorcraft Mercon SP and if I recall a full 18 quarts would have set me back approximately 75-100 dollars (can't remember exactly).
Well, if nothing else, at least I was able to give you some info...
Patrick
Thanks for trying guys - looks like I'll just have to take it in and have it done - can't put it off any longer and keep driving it like it is.
Just one of them deals where I was trying to save a few bucks. Been a whole ton of unexpected expenses lately - $500 here, $500 there - at least this is only around $300 - :rolleyes:
Ron
dennisj2003
Lizemores/WV
Sorry guys had that link saved and didnt pay attention to the end of it.
Dont have the rest.
Ford changed mine for $165 the last time about 18 months ago almost time again the big 60,000 is rolling up and the price has prob gone up also.:(
