7.3L 6spd Clutches??
Nazty 4X4
Chatsworth, NJ
What hp can a stock clutch hold??
My stock clutch has 93,000 miles on it.
Just ordered php custom tunes, stage II injectors, gt38R turbo, cfm intake manifold.
truck already has afe intake and 4" exhaust
If I burn mine up I was thinking of going w/ a south bend clutch.
Tx_Atty
Master Baiter
Fishin'
research the noise associated with single mass flywheels. I bought the Con O and hated the gear growl. Not unique to the Con O but related to flywheel. Dual mass is more expensive though.
* Not much :sly
** With 93K ? IMO, Yer lucky you've made it this far.
A South Bend, Luk, Cleavland, would be good choices. Go with WHOLE clutch assembly, not just the plate. The OEM pieces & parts are Not the what is needed.. as compared.
I went with the LUK setup... 100K ago.. It has served me well.
Nazty 4X4
Chatsworth, NJ
thanks for the info. I was looking at south bends for about $700 to $800.
Ill have to check out luk!
selphdanny
sorrento fl
i blew the springs out of my clutch and all i had was a ts 6 pos chip. i went with a "clutch masters" stage 1. got some hard miles on it and it still feels brand new. i believe i only payed 600 for it
Svttim
