8 inch lift
chris o.
henderson, nv
about to do an 8 inch lift on my 02 4 door 4x4 f-350 long bed 7.3. has anyone had to do any drive line mods?
georgetown texas
well you'll have to drop the carrier bearing to prevent vibrations. The kit should come with a front drive shaft spacer too.
Red Monkey
Alabaster, AL
A buddy of mine did that to his truck. After he drove it a while he wishes he had keep it stock or went with a 2 inch lift.!! Fuel milage went way down and the ride went south...
Good luck!
chris o.
henderson, nv
thanks for the reply! thats all my friend did. but i asked some custom shops and they said posibly have to lengthen and cv.... havent heard of anyone having to do this.
kjdavis
Oregon City, OR
I have an 8" superlift on my 02 cc sb F350. I didnt have to lenthen any of the driveshafts, but I probably should do the front. With the rear, Im fighting driveline vibes and cant seem to get it right with the carrier bearing drop. Im hearing from several people that they say dont mess with it, just do a 1 piece driveline and be done with it.
motoxfreak
San Antonio, Texas
lift
I have an 8 on my truck and I love it. I used the drop for the carrier bearing that came with the kit and it worked perfectly. I have not had any vibration from the carrier bearing. I have had it on for about 70K miles without incident. If you are going with much larger tires, the best thing I have spent my money on to date is the gears. I am back on the highways turning about 2200 RPM and it will give you back the power you lose with the big tires.
bigdave461
channahon il
all u have to do is do the shim kit for the carrier bearing and it will be fine u may have to add a shim or too to it to get it right though
patrickc
Ontario, Canada
I originally installed a 8" skyjacker 'softride' lift (all spring) in my truck and it rode far better than it ever did stock. Later on I wan't to go bigger and installed procomp's 2" shackle and hanger kit. I got lucky with 8" of lift and had no vibes at all. I shimmed my carrier bearing down 2 1/2" with a piece of square tubing (for the strength factor) and used some long 1/2" grade 8 bolts to hold everything in place. I also didn't have any problems with my front shaft but it was at it's limit. After I installed the shackle and hanger kit I did have to have the rear driveshaft lengthened (just the rear section) and also install a front driveshaft spacer which I also got from procomp.
