95 crew cab traction bars.
94f450sd
certified nutjob
plymouth,ma
how far forward do i want them to go?i was thinking i could go right up to the front spring bushing and be fine.would a little back/forth play be ok?i have a set of bars that i can get but one end has a slot instead of a bolt hole.so they can move forward a little.
The longer they are the more leverage they will have just don't make them so long that you get high centered on them. Forward and back is fine just as long as they stop the axle wrap which is up and down on the end of the bar.
BriannaDawley82
