95issues, hard starting, miss,IDM?
dialedin86
dialedin86
Auburn, CA
I recently got a hard start issue...warm or cold, then prior to that
on start up or coming to a stop after driving ( quick slow downs, stops)
I get a low idle, like miss. any ideas...IDM???
I changed the right bank v/c gasket and harness six months ago because
it was fried.
any leads be helpful
batteries are six months old, check grounds, terminals ok
thanks
I have 235,000 on it
Possibly the IPR (injection pressure regulator) valve O-rings.
Welcome to the site. Glad to have you with us and I am confident that we will solve your hard start issue.
Welcome to Super Duty Diesel, Dialedin86. You are in good company here. Please fill out your signature by going to the User CP button above and show what you drive and the area where you live so we can better help you.
Dave :)
roosterdiesel
Earl needs B100
Amarillo,TX
I recently got a hard start issue...warm or cold, ....
Welcome to SDD!
Have you ever replaced injector o-rings? Mine would be hard to start sometimes recently and would blow clouds of white smoke. I found myy o-rings were shot when I replaced the injectors yestereday.
dialedin86
dialedin86
Auburn, CA
well I finally narrowed it down to the starter had an excessive load when
cranking. I am still going to check the ipr, but currently am changing the oil filter housing. do you have to remove the exhaust manifold??? to reinstall it??
