97 psd ...cranks..wont start
smpleman68
Placerville
No WTS light,bulb good,works when grounded
Checked and jumped glow plug relay
#22 Fuse, ok and changed
Tried with ICP disconected
New fuel filter,has fuel pressure
Tach at aprox 200 rpm when cranking
No smoke at tail pipe
No chip or mods.
Any Ideas what to check next????:dunno
should fuel bowl fill up with key on(elec pump?), fills while cranking only..
Any help would be great...Thanks in advance
Tbar
SDD STAFF/Moderator
Batteries.................???
Tbar
smpleman68
Placerville
Batteries good(also jumped off my 6.0 service truck)
Have my spare Cam sensor,may try tomorrow in the light, Tach does show rpm though....
ltfox
utah
No chip or mods.
No WTS light usually means the pcm has no power. Double check all fuses.
As far as the fuel bowl, ya have a mechanical fuel pump so it'll only pump when cranking or running.
smpleman68
Placerville
All fuses good, also noticed WTS light comes on for a split second.
...thank for replies so far...
Zookie400
I WANNA GO FAST
wallingford, CT
WAS ANYBODY RECENTLY WELDING ON THIS TRUCK WITH THE BATTS CONNECTED??? sorry for caps didnt mean to yell.
smpleman68
Placerville
All fuses good...triple checked...lol
No welding on it at all.
ok....wts light...comes on very dim for a split second,CES comes on bright but for a couple seconds.
When i jump GPR does arc..so glow plugs seem to be drawing current.
I parked the truck 3 days ago, all seemed normal....
I've been checking connections...no corrsion...that i have found..
Thanks for all your input so far...I love a challenge...:rant
