99 7.3
7.3 fan
clarksville tn
I have a 99 f350 7.3. it will only start and run with either until i turn it off and then try to restart and have to use either again. i have replaced the ipr the icp and new fuel filter what is the problem can some one help pleeease
Being a 99 (13 years old)
Sounds like you need to do a complete diagnostic check out on your Glow Plug circuit(s). Glow Plug relay, and All 8 Glow Plugs.
OBTW.. WELCOME to SDD.
thanks and do u think it could be glow plugs it is 95% where i am
Yes.
When you turn the key on.. Hot or Cold... the PCM does a systems Check, unless it gets the right data returns.. from a number of circuits & components, it WON'T Start.
Yer shooting either in to it.. it can't HELP but start.. because of the [explosion] (yes, EXSPLOSION) (not, Detonation) created by pure.. high compression.... and either.
Yer call, but you REALY need to get the GP curcuits verified and working.
Either WILL..... be making holes in things, where there shouldn't be holes. (pistons, gaskets, seals and things)
