99 to 08 front sheet metal
not w/out modification...although plenty have done it <already>.
the issue primarily is the HOOD/Grill on the 08...the 08 fenders also
changed (side vent).
the grill & lights are basically the same from 99-04 (cosmetic changes)
and assuming were NOT talking about sealed beam headlights.
the 05-07 grill and headlights changed just enough that you have to
modify the housing behind the headlights and the grill if you expect 'em
to fit on a 99-04
in 08 SIGNIFICANT changes to the hood (grill is attached) occurred and
require the replacement of the front clip (for the most part).
02SilverStroke
Collin County, Texas
Like Bush said, you've got to deal with a different type of hood since the 08 grille is part of the hood. The latch will be in a different spot.
Diesel
Cetane Addict
Great State Of Texas
The bend on the front of the fenders is different from 99-07 to 08. You have to get the hood,fenders,grille,bumper,headlights and the front core support. Then you have to modify the mounting point on the frame to attached the bumper and hood latch.
I considered this for my project truck more than once, but decided it was just too much hassle.
I say go for it, then do a write up for everyone.
castellscl
