A Little White Smoke...?
patshea098
Braselton Georgia
hey guys, just on this last tank of gas i noticed something. Im getting a little bit of white smoke coming from the exhaust.
It ONLY occurs when i let off the gas and the RPMs fall as i slow down. But if im on the gas, put it under a load, or go WOT its all black smoke all day. at a stand still no white smoke. But when i do let off the gas and it happens it only happens for a second or two. What could be the source of this specific occurance. Id hate for my engine to become hydro-locked.
What truck are you referring to? If you had filled out your signature, we would not have to ask. Go to the QUICK LINKS in the BLUE LINE above and click on Edit Signature and fill it out. This will help us better help you. Thank you,
Dave :)
patshea098
Braselton Georgia
yes it has diesel innovations 6 position tuner.....it has always had it...and this JUST started happening...
i do have a slight oil leak i jsut noticed too by the way. anything i should check with the engine coolant?
patshea098
Braselton Georgia
this is exactly what its doing.
-upon a acceleration/load its no smoke/black smoke depending on how hard acceleration.
-when going faster 50mph+ and i let off the throttle no white smoke.
-when going less then 50mph and let off the gas it gives white smoke for a few seconds.
-under a very light acceleration theres white smoke
-a small oil leak
seems to be getting a little worse.
So what is a list of things i can check out that would cause this? cause like i said its really only when off the throttle. i need help ASAP because i dont have another vehicle and i dont want a hydro locked vehicle...
