a new smilie?
94f450sd
certified nutjob
plymouth,ma
hopefully it works.i dont know where it came from but i seen it on another site.can we have it?
94f450sd
certified nutjob
plymouth,ma
well we could have somebody modify it and put a ford emblem on the shark and a chevy or dodge emblem on the little guy.or 7.3 on the shark and6.0 on the little guy.oh the possibilitiesare endless :roflmao :roflmao
W4RLR
High Tech Hillbilly
Sewanee, TN
94f450sd said:
well we could have somebody modify it and put ... 7.3 on the shark and 6.0 on the little guy. oh the possibilities are endless :roflmao :roflmao
Or we could put SDD on the shark and TDS on the little guy!
Its a neat smiley but inserted in text it will make for huge line spacing and a generally crappy looking reply.
What you would end up with is this,
Diesel fuel is very similar to heating oil which is used in central heating. In Europe,
the United States and Canada, taxes on diesel fuel are higher than on heating oil due to the fuel tax, and in those areas, heating oil is marked with fuel dyes and trace chemicals to prevent and detect tax fraud. Similarly, "untaxed" diesel is available in the United States, which is available for use primarily in agricultural applications such as for tractor fuel. This untaxed diesel is also dyed red for identification purposes, and should a person be found to be using this untaxed diesel fuel for a typically taxed purpose (such as "over-the-road", or driving use), the user can be fined $10,000 USD on the spot. Also, in the United Kingdom and Northern Ireland it is known as red diesel, and is also used by agricultural vehicles. Diesel fuel, or Marked Gas Oil is dyed green in the Republic of Ireland. The term DERV (short for "diesel engined road vehicle") is also used in the UK as a synonym for diesel fuel. In India, taxes on diesel fuel are lower than on gasoline as majority of the transportation, that transports grains and other essential commodities across the country, runs on diesel.
Diesel is used in diesel engines, a type of internal combustion engine. Rudolf Diesel originally designed the diesel engine to use coal dust as a fuel, but oil proved more effective. Diesel engines are used in cars, trucks, motorcycles, boats and locomotives.
Packard diesel motors were used in aircraft as early as 1927, and Charles Lindbergh flew a Stinson SM1B with a Packard Diesel in 1928. A Packard diesel motor designed by L.M. Woolson
was fitted to a Stinson X7654, and in 1929 it was flown 1000 km non-stop from Detroit to Langley, Virginia (near Washington, D.C.). In 1931, Walter Lees and Fredrick Brossy set the nonstop flight record flying a Bellanca powered by a Packard Diesel for 84h 32m.
The very first diesel-engine automobile trip was completed on January 6, 1930. The trip was from Indianapolis to New York City - a distance of nearly 800 miles (1300 km). This feat helped to prove the usefulness of the internal combustion engine. The following year
Dave Evans drove his Cummins Diesel Special to a nonstop finish in the Indianapolis 500, the first time a car had completed the race without a pit stop. That car and a later Cummins Diesel Special are on display at the Indianapolis Motor Speedway Hall of Fame Museum[4].
Westport claims to have invented a process called Westport-Cycle [5] with comparable efficiency using natural gas and petrodiesel.
Audi will fight for the overall win at the 24 Hours of Le Mans in 2006 with the Diesel-powered R10. This is the first time a maker has competed for the overall prize with a Diesel-fueled vehicle.
