nagging hi-frequency vibration for the last 20,000 or so..
been trying to pay off debt so not a lot of jingle left over for "non-essential" (ie, will still get back & forth to work) repairs...
so as I got time...
changed all the u-joints.. AGAIN... no change
changed the carrier bearing... AGAIN.... no change
changed the slip yoke... thought I had it on that one.. until I hit an expansion joint in I-465 and viberated all the way down to Bloomington and back home...
pulled the driveline and sent it out for balancing... another step forward until I hit an expansion joint on I-94...
so FINALLY I pull the driveshaft again, and send it to another driveline shop... this time, he replaces all the companion flanges. So I buy the one for the rear diff as well...
while I have it off I check the pinion bearing...
so a set of pinion & carrier bearings, all the yokes and companion flanges, support bearing, balanced twice and three sets of U-joints and A THOUSAND AND THREE HUNDRED FREEKING DOLLARS later.. I finally have a truck that doesn't put your feet to sleep at 70 mph again..
remember the second sentence when I said I was "trying to pay down some debt?"
so as I got time...
