AC
bonestroker
stroke it if you got it
In the field
can't figer it out my ac works for about 10 to 15 mins then it blows nothing but hot air if you stomp on the pedel it'll go back to cold for about 5 mins then hot do you think it needs recharged or is the pump going out please help this 5 hr drive is to hot to do and I can't stand the window noise. thank bone:confused:
Wood County Tx
low charge
evap plugging up
but i bet is low charge,
sounds like the charge get slow on return pressure so it shuts off, the as the fluid to gas and gas to fluid settle back down it allows the low pressure switch to reset.
have some one with a set of gauges hook up and see whats really going on, dont just dump in a can of 134, to much is bad to
firedude9052000
I drive a 2k ambulance at work diesel 7.3 ltr and it does the exact same thing and we found out that it the condenser was freezing up because it was low on "juice". so you may check the "juice" level.
Tyler
bonestroker
In the field
I put 2 cans in this afternoon working better not kicking out many I think it needs 1 more going to call ford in the morn to see how much it holds :confused: :dunno
bonestroker
In the field
I get the same code (1211) if I get my egt over 1200 or get above 100mph on the way home from work there is one part of the road about 40 miles long I trying to get home before I go to sleep I stand on it. The last 2 times coming home I set cruse at 95 and it don't set it off :innocent :wow
MUDWHISTLE
Diesel Lover
oregon
Check the short harness going to the compressor clutch they are very common for having a broken wire in them when the a/c quits open the hood and leave the a/c on observe that the compressor clutch is not turning and then wiggle the harness from the clutch to about 8 inches away good chance it will start working.
nevrnf
NW IL
do you have the part # of the harness? I tried my local dealer by phone and he could only find replacemet ends for the harness.
