Accelerator Pedal Position Sensor
jguzman75
McAllen, Texas
Mission,Texas
Does anyone have a part number for a 2000 F-250 Diesel? How about a place to purchase one besided the stealer :)
jguzman75, this is the only thing I found at this time. It's a DORMAN # check with your local auto parts store and give them this number. Take your old one with you to match up.
699-201 Accelerator Pedal Switch
I have some tec books on it, I'll see if I can PM you the info I have.
jguzman75, see if this helps. This is off a new truck. but this is all ford gives on there tek disc.
forddeerediesel
Logan Co. Ohio
Why are you wanting to repalce the senser??? Is it broke or are you upgrading for responsiveness??? Seems like my pedal moves a long ways before the motor responds. thanks!!!
godofdew11
where is the bus today?
the sensors have a bad habit of going bad, getting dead spots, not reacting at all sometimes, my dads 99 been through 2 of them. sometimes coming from stop signs you could put the pedal to the floor a time or two with nothing, then it would come back on its own. the dealership will only sell you the whole pedal assembly for hundreds of dollars, napa has just the sensor dont have the part# right now.
is that a john deere A? '49?
