Adding Cab Clearance Lights
Metalhead
Round Rock, TX
I want to add clearance lights to my truck. I'm looking for the teardrop shape 5-light pattern to put on my truck. I'm looking to put ONLY the LED style on here. I can't find anything at local parts stores, and I want this to look good once I'm done. Has anyone got any suggestions for what kind of lights I should get?
AK Rover
Kenai, Alaska
Recon makes the LED clearance lights and they even have a kit with the wiring harness to plug in to the factory connector behind the passenger side kick panel. Check out Recon's website for more information.
Tx_Atty
Master Baiter
Fishin'
I bought 5 teardrop lights from Advance Auto Parts (maybe Car Quest) for about $5 each and ordered LED bulbs online for 2$ each. I made my own wire harness and plugged it into the plug behind the passenger kick panel. Very easy and a lot cheaper than any pre- made package.
BIGMike
Pasadena/Maryland
Lights
Hello Metalhead,
I bought the Recon LED lights and they look good but there's no pattern so I had to do alot of measuring. If you have someone that has the lights on there truck I suggest you make a pattern if will make things easier and good luck.
Under the headliner is some holes and clips for the lights. That is what I used to set my light pattern to. It is pretty clear where they go after you pull down the headliner.
clintusaf
Clint
Bossier City
I am lookin at doing this some time in the near future as well. my question is why dont all our trucks have them?
architect-builder
Jerome, Idaho
They are standard on a dually, optional on others. I did not think I liked them when I ordered mine, then started liking the look after, so bit the bullet and drilled.
Barrett
Not sure if it still is.. but the Cab & DOT lights under/on the tailgate was/is Required.. on 1 Ton.. and above trucks. DOT/ICC/NTSB stuff.
Metalhead
Round Rock, TX
Thanks for all the feedback. I went ahead and got a set of Recon LED lights on order. Looking forward to putting them on soon!
