Adjustable Regulator Kit, or Regulated Return Kit
whatabudro
Launched
Scar13 said:
Whats the diffrence between these two kits?
http://www.dieselsite.com/index.asp?PageAction=VIEWPROD&ProdID=440
That is not a regulated return. It only puts a regulator into the system to allow you to adjust pressure more accurately than shimming. It still uses the factory dead head system in the cylinder heads which leads to aeration of the fuel for the back cylinders
and
http://www.itpdiesel.com/store.php?crn=152&rn=277&action=show_detail
ITP 7.3L Regulated Return Kit
That is a regulated return system;)
CSIPSD
Bend, OR
Bobs is just a pressure regulater, and Dennis's (ITP) is a full fuel system to eleminate the dead head. Bob has a full kit too. but they are two differant things
Fire1
Certified Diesel Driver
The Diesel Site item is simply and adjustable regulator allowing you to easily adjust fuel pressure. It does not address other fuel issues such as the dead end fuel rail which may trap air and also starve the #8 injector.
The ITP regulated return, Diesel Site CPR system, and Diesel Innovations Regualted return will do all of the above. They allow pressure adjustment and address the other issue by creating a flow through design.
I have none of the above, but would love someone to buy me one. Hint, Hint!
