Aftermarket exhaust
Theo Gil
Northglenn Colorado
So I'm putting a 5" turbo back system on my 04 f-250. I live in Colorado and have to do emissions every 2 years. How can I adapt my stock cat to the 5" system easily so that I can reinstall it come time to do emissions and that go back to the 5" system? Pictures would be great for the fabrication process. Thanks
01yellerCobra
Cali
If you're leaving the cat in place you shouldn't need to swap anything come emission time. As long as the cat is in the factory location you should be good. At least that's how it is in Cali.
As for fabrication, you just need the right size reducers and a good welder.
jimdevfishing
Well first thing you can do is replace those Democrats (liberals) LOL!!! they cause a lot of frustration LOL!
One thing you can do, if you know a great welder, I believe the 2008-09 has a bolting flange between the two parts check that out! But a bolting flange would probably work fine. Then you can add or remove it when you go for a inspection.
Just a thought....
