An odd thing showed up with Mr. Brown
Wood County Tx
My UPS man left me a nice little package yesterday, Now if it would quit raining it might get put on.
Its about 4" in diameter, maybe 28" long, has two bolts is almost straight, My arm goes right through :D :D :D
even did a few elephant imitations as i put it in the cargo trailer for safe storage :roflmao
hoping it helps with the nice bluish coloring of a certain engine acessory, and some egts lowering a bit :eek:
roosterdiesel
Earl needs B100
Amarillo,TX
:roflmao :roflmao That was interesting mental picture. Preparing it for some more hot air were ya.:eek: :D
Wood County Tx
are ya saying i got some air issues :roflmao :roflmao
wife got a laugh as did the neigbor
insert elepahant noise and see me holding it by frame support, :D
my present factory restrictor thingy :D ,right under the passenger seat is becoming a liability to performance, I got a hissing noise under moderate go pedal squeezing :confused:
wife called it a testoterone mod :roflmao
roosterdiesel
Earl needs B100
Amarillo,TX
Hissing? Not a boost leak?
We all know you have issues Robert.:roflmao
Aren't they all testosterone mods?
Wood County Tx
antonio
I thought it was boost, did the clamp checks and tightening drill.
then i noticed at last oil change the DP was a nice pretty blueish gold tint right in front of and on the odd peice of plumbing, and a nice big SOOT burn on the floor pan, that was seal number 2, so i will "test" the big restictor out of the way and see if i can get it "un clogged" :D in case i need it when we finally register the truck out thar in Tejas :sweet
my oil guard box arrived as well, first time my wife saw the airfilter :eek: :eek:
she just shook her head and smiled,
the pipe piece was the best, I told her is was a replacement test thingy to prevent grass fires at the lake place, then it showed up and she was :roflmao , because my silver tongue talk never quite said it was a 4" pipe :D :D :D
roosterdiesel
Earl needs B100
Amarillo,TX
I figured you checked, just making sure your age didn't let boost leak slip your mind.:eek:
I got the same look when the GF saw my air filter order. Three 6637 boxes taped together. "That's your filter?".... "No it's 3" pulled one out and got the head shake.:D
Wood County Tx
sort of like "blazing saddles" [ pardon me, while i pull this out] :roflmao :roflmao
hopefully tonight the rain is gone and the ground is dry enough to get under there and do a swapp out,
I may wait till thurs night, she has an appointment tomorrow with the dealer for a check up , tranny is doing a weird stuff, long delay reverse to drive
F350DRW1
Waylon Fan
N.J.
Yeah, they run real nice with the 'ol "Test Pipe". Mine was part of a stainless 4" MBRP system from the turbo back. Less EGT, turbo whines nicely...:burnit
Wood County Tx
I am looking for anothe 100-150 egts lowering pulling the fiver, that would be great :D
whatabudro
Launched
Then quit racin other brand's diesels with it. :deal
Hey are you comin to the Rally or not, you sure are hush-hush about it.-popcorn
