Another Bio Newbee Question
dboyw
Lancaster, PA
I have done some reading, but not much. Kids and wife help with that.
Here is my question. I have about 5 gal of used canola oil that was for my turkey fryer. Can I just pour some in to the fuel tank. to mix with the diesel that is in there? This would be after pouring it through several layers of cotton cloth several times.
Is this OK, or should I do something else?
Thanks for the answers into my first attempt at Bio.
Tx_Atty
Master Baiter
Fishin'
If I remember correctly, the two will not stay mixed and will separate so the recommendation is dont. True bio would require a processing of the wvo first. If you want to make true bio, hte appleseed processor is the current "standard" (for lack of a better term).
check the national biodiesel board (www.biodiesel.org I think) for sellers in your area too.
hheynow
Señor Aceite de Soja
Northern California
WVO (your canola fryer oil) is not biodiesel. To make biodiesel WVO is filtered (not through cheesecloth), dried (water removal) then mixed with methanol and lye (catalyst). A reaction takes place where the methanol replaces the glycerin, which drops out of solution yielding a thinner oil. That's biodiesel. That's an over simplification.
Fire1
Certified Diesel Driver
It is not Biodiesel, but YES after filtering just dump it in with a tank of Diesel. I have.
Wood County Tx
i diluted pure peanut oil, and it ran fine, as for canola????
i filtered the peanut oil through a 2 micron ss mesh filter to remove the seasonings:D
i didn notice i was hungry after driving around in traffic, kept thinking of turkeys basted in cajun rub :eek: :D
94f450sd
certified nutjob
plymouth,ma
i fixed one of our members trucks the other day.he runs on bio and WVO.gave me 5 gallons of bio to try in one of my trucks.i dumped it in my 94.ran around for 2 1/2 days with a craving for french fries.a couple friends didnt believe me that the members trucks exhaust smelled like french fries so i fired it up for them and they were like "what the hell,it does smell like fries":roflmao :roflmao :D
shannoncaldwell
Filtering Waste Vegetable Oil (WVO)
Not to beat a dead horse, but everybody here is correct, biodiesel and vegetable oil are two totally different things.
If looking into running on WVO take a look at www.cleangrease.com for ideas on filtration prior to putting in your tank.:thumbs
