Anti-Static Strap
EXCURSIONCRUISER
Glendale, Arizona
Hello All,
Does anyone know where I can get a anti-static strap that I can attach to my Excursion so I can stop being shock when I slide out of it.:thanks
Robbie
2001 White, Limited, 2wd,PSD, Excursion
What two portions of the vehicle does this strap connect to in order to prevent static discharge?
A length of chain works too, but you wouldnt catch me draggin a chain around under my rig.:cop
maniac
Ct
I spray some static guard on the seats a couple of times a year, seems to do the trick.
For some reason I only get shocked when I wear sneakers:dunno
Alexandria, Virginia
This is what my wife uses in her car during the winter months -
# Instantly eliminates static cling.
# Static Guard instantly eliminates static electricity and prevents static build up.
# So avoid embarrassing static-cling on clothing with Static Guard.
# Static Guard is:
* Safe On All Colorfast Fabrics -
o Even safe on silk, satin, wool and fine cotton
* Easy to Use -
o Simply spray on skirts, dresses, pants, socks, lingerie
* Works Instantly -
o Eliminates static on contact
* Lasts All Day -
o One application is usually all you need.
# Also Use Static Guard to:
* Easily Remove Pet Hair -
o Spray on clothing, drapes and upholstery.
o Wait one minute and brush or vacuum
* Protect Computer Memory -
o Spray on carpeting around computer area (avoid spraying directly on computer)
* Stop Flyaway Hair -
o Spray on brush before styling - it's gentle and residue free.
Ron
Didn't see your reply - started to type - had to run upstairs and came back to finish the reply - wife says it works great for her.
Ron
Also............. If you dont wear the polyester leisure suit in the winter time you wont get as much static either.:tounge
:lmao:lmao:lmao
DavidJ
DavidJ
SoCal
:roflmao :roflmao :roflmao
I used to use an old leather belt years ago to keep radar from locking on.
The funny thing is I can't remember if it ever worked for either?:dunno, I sure could use one as well, Thanks for the direction CHP:thumbs.
EXCURSIONCRUISER
Glendale, Arizona
Thanks to all. CHPMustang helpful links were what I was looking for. Some of my PT friends use them on the cars and like them will see how it works.:hail
Robbie
2001 Limited, 2WD PSD.
