auto shift cable
bigfootpsd96
Norfolk,Va
has anyone else ever had their shift cable stretch beyond the point of no return. ive been under the truck and played with the adjuster and no dice. just making sure im not missing something. its annoying because when i put it in park it wont engage the NSS for the truck to start so i have to always start it in neutral and the real good one....even if u slam it into park it will go out of gear and then suddenly drop into reverse.........(yes got out of the truck one day with it running and i go 5 feet from the truck and it took off in reverse:censored: ) i was wondering if anyone else has had this problem.:dunno
check for physical problems moving the lever by hand while you're under the truck with the cable disconnected.
96EDGEpsd
Welding/Fabrication
New York
ive had very similar problems, under the steering colomn where the cable pivots, there is a torqs screw that kept loosening up on mine, sounds like it mite b ur prob too
bigfootpsd96
Norfolk,Va
nate also when u were in a given gear was there still alot of movement in the shifter?
but i have nothing else to do at the moment sooo i think ill go check it out.
bigfootpsd96
Norfolk,Va
yeah that was it.....both of the bolts for the bracket were lose.....thanks for the insight.
brandon
