Autometer gauges messing up
mike.germann
Lexington Park/MD
Recently my gauges have been acting up. It doesn't happen every time, but the past few times I've looked at them while driving around, all the gauges have had bogus readings.
Not sure if there is a wiring problem, or what. The attached picture shows the gauges after almost an hour of highway driving. ??
I don't know how these kinds of gauges are setup. Are they just wired gauges?
My gauges are as follows, top to bottom: pyro, boost, fuel press, trans temp.
PS. My fuel pressure gauge isn't hooked up, it doesn't actually have 110 PSI. lol
Any input would be appreciated!
most gauge problems can be traced to poor grounds..
I used Auto Meter gauges in my race car back in the '80's, and they DON'T go bad.
I am going to side with JL on this one. Check your grounds, carefully. Run a ground wire from the gauges to a good chassis ground.
X3 on bad grounds.
I've found that (Gang) wiring all the gage grounds together.. near the gages.. then running One wire.. grounded to a ground that Ford used.. under the dash.. is the way to go, for me.
:dunno
Same thing with the lighting (?).. One wire, tied into one dash light wire.
mike.germann
Lexington Park/MD
THANKS FELLAS :D
Next question: where would I find the ground wire for it? I've never had to mess with them before, so I dunno
:dunno
Also, would that have anything to do with the lights behind my speedometer going out? From 90-100MPH isn't illumiated anymore, neither are the 2 stock dummy gauges on the far left :dunno:dunno:dunno
THANKS FELLAS :D
:dunno
Something the PO did ?
If so... yul just halfta try and figure out what he did. Pull one gage out and see if he used a black wire for the ground... look under the dash for a black wire coming down from the corner of the dash... hopefully.. you can trace that to where he grounded it.
As far as the dash lights (?) the ground issues could be related.
The grounds are generally tied to a small bolt under the dash. This is called a chassis ground.
Dave :)
mike.germann
Lexington Park/MD
update: thanks everyone!
found the problem..it was simple. My inner rubber door seal had got wedged in a weird way, and with the recent rain, water was slowly trickling down the A-pillar and so the wires got a little wet. I didn't notice any bare wire contact, but I let it air out a bit to prevent corrosion (somewhat).
I was wondering why I had a leak all of a sudden :O AAAHH I'm getting rained on!
Definitely glad MOST of my problems have been easy fixes :D:D:D:D:D:D
Thanks to everyone for the input!
