Axle seal
97 CREWCAB
OBS RULES!
Dunkirk, MD
Has anyone replaced the RDS seals on the front axle shafts? The one that goes on the outboard shaft comes with the new spindles but nobody can seem to find the inner one. Keep giving me the one that goes inside the pumpkin.
hdjeff
Medina, Ohio
do you mean the seals the go on the inside of the spindle? where the axles goes through. if so yes, ford sells them at i believe $18-20 a peice. i just replaced mine this winter
97 CREWCAB
OBS RULES!
Dunkirk, MD
No. There are 2 seals on the axle shaft itself. One on the inner shaft that seals off the tube and one on the outer shaft that seals up the spindle bearing.
