bama help!
whipittire
connecticut
i have an 08 f450. im pullin a 15000lb 5th wheel. i would also like the hitch i buy to transform into a gooseneck,like the reese signature series. your opinion? thanx
The hitch that I used was a Hidden Hitch. I only used the 5th. wheel but you could also use a ball hitch.
It was two seperate pieces.
I'm sure alot of manuf. offer the same set-up.
I can only speak of the one that I used.
I'm sure some others will give their opinions too.
BudMan
North Central Illinois
I pull professionally as an RV transporter
and I used a B&W turnover ball gooseneck with a Companion 5th wheel. The 5'er is rated at 18K and the goose is rated at 30K.
BudMan
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
Husky Towing (scroll about half way down page) has a stowable goose neck ball system rated for 30K that will mount a 5th wheel hitch in any of several different capacities. The goose neck ball freely rotates to eliminate gooseneck binding.
Husky hitches are available from many RV & Trailer dealers across the US & Canada.
Jeffro
Bloomfield,NM
B&W no other!
I have two FORD trucks with B&W gooseneck hitches in them and I have no problems with them and will give them a thumbs up to everone!
whipittire
connecticut
when you take out the b&w is the bed clear? no rail or anything? and is it both a 5th wheel and a gooseneck?
sagebel
Stock? Pfft!
Albuquerque, NM
Yes, there is a 2.5" square tube in the bed that the GN ball or the fifth wheel base fit into. You will also have the two hoops for safety chains.
jpringle83
WA
i have the reese pro series and have both the gooseneck and fifth wheel the rails are very low profile and don't really seem to get in the way but if i had to do it again i would go with their signature series being that it just leaves the four rubber grommets that are flush with the bed
