Banging Drive Shaft HELP HELP
LandonSchert
NC
i have a 99 PSD with 8.5 lift and 38's on hard acceleration. In 2wd the drive shaft bangs the body (where the drive shaft enters the transfer case) and you can see where the transfer-case is hitting. also i have no idea nor do any mechanics in the area? HELP PLZ:confused: PS the mechanics the didnt say the lift was the problem said the center support bearing and the trans. mount along with motor mount all have been replaced still no fix?
If the transmission and Universals is tagging the floorpan I'd say mounts for sure.
no-red 6 0
Senioritis
southmetro MN
THAT IS NOT GOOD. i would stop driving and get it towed in to get serviced. no need to damage anything or ANYONE further...
i would say mounts somewhere loose too.
good luck
Wingdog
Thunder Bay, Ontario
If the mounts were just done in it then I would say that either something is busted or someone forgot to put some nuts were they should be.
LandonSchert
NC
Thanks CHP Mustang for the pic.s ill check the mount and repost to let you all know what's up Thanks for the info
