BATT sugestions
mille-ryan
Loco Parts Changer
North Platte,NE
Well go figure had the big X 2 weeks and the batt's have crapped out tonight.I shoulda checke dbetter on the eye indicator.But oh well need to get some replacemnets tomorrow and dont have tons too spend.Is the a certion systle or type I need or certian ones to stay away from.Info greatly appreciated.
W4RLR
High Tech Hillbilly
Sewanee, TN
A lot of folks here will tell you that you can't go wrong with replacement Motorcraft batteries. Most aftermarket batteries are made by two big manufacturers, Johnson Controls being one of them.
oi8228oi
another 99
i always suggest staying away from Die Hard batts(sears brand). although they have good warrentee (spell check) and are very good about taking em back i still have had tooo many problem with em making me feel like there not worth it.
I am one of those guys that will tell you that Motorcrafts are the best out there. With that said I would venture to guess that yours are not bad yet since they are only 3 years old. I have a set that are 10 years old and still going strong. Clean the terminals and they might just come back to life. A little corrosion or looseness on the terminals will cause them to not get a good charge and appear to be dead. Are you sure the alternator is working? It could be the batteries but Motorcrafts usually last much longer than three years unless they have been severely abused.
There is a device you can plug into your batteries that will "desulphate" them. THis is the leading cause of batteries going bad. Look at; www.batterylifesaver.com for more info about the desulphator. I have one and I can tell it is working.
Dave :)
mille-ryan
Loco Parts Changer
North Platte,NE
Thanks, I know one pos terminal had a lot of corrosion buildning up on it, i cleaned a bunch off, just didnt have baking soda at the time to clean up good.When I bet the vehicl eI noticed it seemd slow to crank too, plus the batts look real nasty on top like they,ve leaked some.Luckily I was able to jump it with a friends bubran last night so I at least both werent dead.Where can you have the batts checked out?
Djracer
Car Stereo Dude
Wetumpka, Alabama
you can use a coke if you don't have baking soda! I'd take all 4 terminal off and clean throughly and tighten them up and charge over night with a 2 amp charge!
X-Hibition
Idaho
If you want to get your batteries checked, and definitely have a load test done, you can go to most places that sell batteries. They usually check them for free, and some will charge them for free (Les Schwab in the Northwest).
It's good customer service, so auto parts and tire shops like to do it.
mille-ryan
Loco Parts Changer
North Platte,NE
Thanks all, a friend of mine works at a jeep dealer and he checked em out.The batts checked good just need charged, the alt however is only puttin out 12.4 V or so.Contacted my dealer to see if its covered on no, so Ill see in a day or so.
