Battery Question
IDSTROKER
Blackfoot ID
Blackfoot ID
I have a 2013 Super duty with the 6.7 diesel.
it start fine every time.
so my battery's are original the have the indicator on the top 1 battery is green the other is black.
The water level is full when I got it serviced back in October at a ford dealer they said one had 550 cca and the other was at 425 cca.
Had the truck in the shop 2 weeks ago for preventive maintenance at the dealer check it all over they say my batteries are good.
I have a load tester and have tested them they do fall down a little bit on the edge of the green and yellow line.
do I bite the bullet and buy new one's or run them till there done.
thanks
01yellerCobra
Cali
Do you want to take the chance of getting stuck somewhere? It seems you have all the clues showing they're on the way out.
