Best Cold Air Intake for the money??
CrAacKker
Houston, TX
I have 03 F250 7.3 stroke. I am on a limited budget and trying to find a decent air intake. I just had my muffler taken off and I have the stock 3.5" exhaust straight with no muffler or cat. I will be getting a chip soon from DP tuner or Tony Wildman...still trying to decide.
Which air intakes would you all suggest?
thanks
Guys
oi8228oi
another 99
well being that you still have a 3.5 exhaust and not a full 4 inch i would be worried about EGTs and would look for the best air intake avaliable (will help keep EGTs down) which would be AFE Stage 2, but if ya go with a different air intake i would definetly do the Zoodad mod...
do you have gauges? if not i would be carefull running the chip on the high HP settings, or towing with the chip.... just :2c
Myself and quite a few other members have the DIY Intake which IMO performs nearly as well as some of the big name branders out there but runs about $50 give or take a few bucks:)
If it came down to where budget wasn't questioned by the XO I'd be eyeballing the AFE stage II :sweet
CrAacKker
Houston, TX
Thanks for the advice.
My goals with the truck are to just make it faster, i won't be doing any type of competitions...rarely ever pull anything. The most I want to do is crack some rice machine's a**.
With that said, I talked with Tony Widlman about the 4" turbo back exhaust and he said that since I wasn't planning on doing injectors that the 4" inch exhaust wouldn't do much compared to the money I was spending unless I had some injectors installed.
CrAacKker
Houston, TX
That is a great idea.Like a lot of the guys on here, I have a family with a child on the way, so I can't justify spending $450 on a intake....
Like you said you could build one your self and save a lot of money and get nearly the same performance. It's not like you are going to gain 50 hp from buying some brand name over building on yourself.
I could buy all my parts at Autozone, Hi Low, and Home Depot...Right??
Thanks again for all the help.
