Biting the bullet and getting a DP Tuner
6LMonster
Wake Forest, NC
Okay guys, I am going to break down and chip my '96 F-250! Here is what I am thinking of going with:
DP Tuner F5
Position 0: No Start
Position 1: Stock
Position 2: High Idle (1200 rpm)
Position 3: 40 HP Tow
Position 4: 60 HP Tow
Position 5: 80 HP Econo
What do you guys think?
Everything on the truck is stock except for a 4" MBRP Exhaust.:sweet
Red Monkey
Alabaster, AL
I would skip the 40 hp tow. Once you use the 60 hp tow you will NEVER use the 40. You will LOVE the 80 hp econo, this is how our trucks should run from the factory. Call DP and discuss how you use your truck with Jody, he has a LOT of experience in steering you in the right directuion.
6LMonster
Wake Forest, NC
So, skip the 40tow and lower the high idle to 1000 rpm....
DP Tuner F5
Position 1: Stock
Position 2: High Idle (1000 rpm)
Position 3: 60 HP Tow
Position 4: 80 HP Econo
Position 5: --
Any other thoughts? I will call Jody once I am ready to order it....
hheynow
Señor Aceite de Soja
Northern California
Apples and oranges. I went with:
stock
40
80
high idle 1,000
no start
I use stock for vegoil
40 when not on vegoil
80 I rarely use
high idle every cold morning :sly
no start for parking at airports and in mall parking lots :rant Damn low lifes!
strokin'_tatsch
death row inmate #7
Austin, Texas
i'm gettin' a 2 position from Jody with a custom switch on the shifter. i'm gettin' the 40 tow and 140 aggressive when i put in the stage 1's
I have a factory aic. The lowest setting on it is 1200 rpm. I set it between 1200 and 1600 depending on temp. When warming up at work this morning I had it on 1750 since it was -42º. I would go with 1200 on a chip.
I would go
Position 1: High Idle (1200 rpm)
Position 2: Stock
Position 5: All out performance
6LMonster
Wake Forest, NC
Alright, so I will call Jody in the next week or so, and get it set up like this:
Position 2: Stock
Position 5: Empty
97powerstroker
north port,fl
will our obs injectors even push out an additional 80hp?i was told max 60hp.any higher setting then that will make the truck bog down.thats what ive heard.if thats not true,what is the limit of additional horse it will make in stock form.:dunno
dserge66
