Question blowing fuses
bling0105
duluth mn
every time i turn the key on to turn the glow plugs on a fuse blows for the fuelheater wastegate solenoid and the injector driver module relay coil i cant even start the truck what would the problem be
bling0105
duluth mn
yeah thats what it was its not bad to run with out it i know that there is two of the an intrnal and xtrnal so i have one
CKyle494
Maryville, TN
Get the replacement heater from International it is ALOT cheaper and bigger than the thin piece of wire from FORD. 26-35 from International and 125-150 from Ford.
