Help Needed bolt patterns
bigkahun74
knox,in
i have a 2002 f250 SDD i currently have the stock wheels on it and have 265/75r/16 tires. i was wanting to know what others year SDD 8 luggers would fit my trucks bolt pattern. also what is the largest size tire i would be able to put on her with no rub on the stock wheels??
thanks,
Mike
Fine69
Cranberry Twp,PA
99-04 wheels will fit your truck as far as bolt pattern and the correct backspacing or offset. 05-09 will have the same bolt pattern, but have the wrong offset. The bolt pattern for all single rear wheel Super Duty's are 8x170mm.
patrickc
Ontario, Canada
The bolt pattern for all single rear wheel Super Duty's are 8x110mm.
They are actually 8 on 170mm. I would say that you would be safe to run a 305 on the stock wheels with and rubbing. I ran a 315/75/R16 for a whole winter without any rubbing but the tires did wear a little funny.
Fine69
Cranberry Twp,PA
My Bad, musta hit the wrong number. Nice catch, thanks:sweet
bigkahun74
knox,in
how would i go about finding the correct offset
