boost psi on 2003 6.0
cj036.0
Huntingtown, MD
what is the stock boost psi on a 2003 6.0 automatic 4x4 s/c ? Does a 4" magna flow exhaust system make any difference ?
Wood County Tx
at 75mph flat ground we noramlly run 10 psi or less, usually less and here lateley when the outside temps have been 60 or less the egts run about 500-650 or so
and yep a freer exhuast will lower egts and possible let teh turbo spool easier which would equate to less lag, but it wont increase boost.
boost is a "on demand" thing
more throttle pressure and load equals more boost in a real simple explanation
but you could be doing 90 and have no real load and boost could be very low
and on the other hand going 40 and pulling a load boost may be 30 lbs
ranger boy
Banned User
I've seen 30 also, the edge was bleepin but i told it to bleep itself
Wood County Tx
WFO Bleep bleep
Wide F Open:eek:
i tried last night climbing the mountian 75 mph and climbing egts 800-950 boost stopped at 30 on the factory gauge, i am starting to believe my factory gauge is not calibrated or just plain not working right, I had the pedal pushing close to the floor about 3/4 throttle,, this a climb of 600 feet in 1.8 miles cant do teh math so i dont know the grade, most trucks hit the top at less than 25mph and SMOKIN
:D :D
