brake light on dash
Rookie
Maple Valley Washington
What would cause it to light up off and on? It just started coming on a couple of days ago. I thought it may be the park brake sticking but that didn't seem to be the cause. Fluids are all up...just wondering what to start looking at...
Oh and I finally made 200,000 miles.I have the picture somewhere. Only took 11 years :D
low brake fluid...which probably means you need to check / replace
the brake pads.
Rookie
Thanks for the suggestions. It's having a service this weekend so I'll have to chance to check them out. I know I'm getting close for rear brakes with 203k on the original shoes.
hheynow
Señor Aceite de Soja
Northern California
To check the vacuum pump unhook the hose to the brake booster and attach a vacuum gauge to the hose. Start the truck and apply the brakes. If the vacuum is greater than 20 inches it's good. If very low it's bad.
Rookie
Perfect, thanks...
Ron
