broke down in missippi
georgetown texas
Driving last night 80mph touched the brake to let off the cruise control and truck shut off. Pulled to the side of the road and truck would not restart. There was no check engine light when the problem happened. Pulled a code of P0465 cant find any info on it not even in the bible. Sitting at the dealership in jackson missippi.
Zookie400
I WANNA GO FAST
wallingford, CT
Ford Non-Enhanced Evaporative Systems: How They Work
i found that by googling "what is the purge flow sensor"
i dont know as it applies to a diesel truck, but being that the 6.0 is an egr engine a change in intake air may screw up the sensors enough to kill the truck, i know the mercedes engines i work on are easily killed by emmission system malfunctions.
i hope all is well for you, being away from home and broke down SUCKS!
no-red 6 0
Senioritis
southmetro MN
rooster,
that suxs...glad all is well....sounds like you're grinding roads in ol'miss??????:dunno
or was this a vaction?
Was it the HPOP that failed or the connector? I thought connector failures on the 03's were non-existant
