Burned fuse
Finn
Porvoo, Finland
Hello Gentlemen
I was changing the small light bulp in 2000 Ex's running board and managed to burn the fuse. ( Stupid me - was cleaning the connector with the screw driver )
Lights inside the truck, windows, mirrors are not working. Driving lights, radio, a/c, mostly everything else is working.
I could not find any broken fuse from either fuse box. I was only cheking the mini-fuses, that I can check by looking.
WHERE IS THE CORRECT BROKEN FUSE PLEASE ?
I do not have the manual.
Jukka
Finn
Porvoo, Finland
And further - if it is a maxi fuse, is there any other same size fuse that is not too vital for driving. I will not be able to get a new fuse before monday earliest, so I need to borrow a fuse from another location.
thanks
Jukka
Finn
Porvoo, Finland
Solved
It was a mini-fuse - 15 A, in the fuse box under the steering, second row from the top, in the middle.
Next time that I ask anything electricity related - just auto-delete my question ( :
I should have seen that myself. again.
Well but atleast I got so pi..off that now I am changing the driver side door lock actuator, been broken for a month.
Jukka
