Camber-Caster Adj.
speckfisher
Missouri City/Texas
Does anyone know where I can get a camber caster adj. cam.?
Im looking for the type that you dial in the camber and then the caster seperate.
All of the places i have found are only business to business not to the public.
Thanks
Frankenstien
Frankestien
South Prairie Wa.
I can only guess you have modded your suspension, as the stock setup has a rather aggressive cam on the Ball joint. I mention this ...just in case you weren't aware.
I looked today at work..
the closest thing I can get ya is a bushing with clocking grooves all the way around it. But that's a compromise, as you will give up caster or camber to gain in the other angle.
what you want is an offset ball joint, a'la Dodge, and then use the bushing to bring camber back.
I didn't see one in Specialty Products' catalog...
what exacty is it you're looking to accomplish, anyway?
speckfisher
Missouri City/Texas
JLDickmon I am looking for Specialty Products part# 24130. If you can tell me how to get them I would appreciate it.
I have camber wear on my tires not to bad but I've been running them like that for a while and they are just worn out.
Thanks
