Can't get DP off.....
jserman
I run over little KIDS!!!
Boise,ID
I have a 99 PSD and I bought a new exhuast for it... I got the rest of the exhuast off but when I went to get the Down pipe off I can't..
I have lossened the band around the turbo but nothing... is there any tricks that I need to know...
Help
Wood County Tx
remove the band clamp completly let it slide down the factory dp
wiggle dp to free it from turbo outlet
a sawzall helps alot to make dp shorter and easier to manuever under truck
it should lift up about 1/2 " then off it comes
forgot HAMMER rubber mallet
jserman
Boise,ID
is there a trick to get the band clamp to come off.... it's loose but won't come off.....
yea I already cut up my stock exhaust so once I get this DP off I am good to go
Keller, TX
We used a rubber mallet at our last mod-party. Whack it from underneath 2-3 times and it will just fall off. :sweet
Tbar
SDD STAFF/Moderator
Spray with your favorite penitrating fluid and while that is working go find a long narrow screw driver and a hammer. Reach around the clamp and find the notched out areas..........this is where your going to place the screw driver tip to give it some love taps. You may think the notches are impossible to reach but keep trying. You will probably have to do it on both sides of the pipe to get it to come loose.
Tbar
jserman
Boise,ID
well I just went and soaked it with brake cleaner so I will give it a minute and see what I can do
brake cleaner will dry it out...you need something to lube
the bolt/nut on the clap so you can loosen it.
dpantazis
#12
under the cheddar curtain
Help
Are you trying to wiggle off the band clamp? Its a clamping wedge mechanism. You will have to whack it pretty good or pry it off the flanges to get it started.
Here is a picture of what they look like-
It should make more sense.
dp
jserman
Boise,ID
well I after working on it for a bit and finguring out what the clamp was looking like I got it off... it was being pretty stuburn....
I guess if you haven't moved in 6 years you wouldn't want to move either...
well I got it off and I got my new DP on...
thanks for the help everyone
