Cat delete
Keep the Cat in the shed if you want to, but don't lose it. You may need it one day if they tighten up the inspections.
lvtitan
prototype
$in city
especially on the 03's right? i think i heard the turbo is a little louder. I cant wait to upgrade my exhaust.
which is exactly why i went with an 03 turbo when i replaced my stocker for an upgraded unit... it has a larger turbine wheel with ten fins as opposed to the o4 which is a couple mm's smaller but has 13 fins
the mbrp test pipe takes 10min from start to finish to remove and re-install
the cat...no CUTTING or welding...dealer/warranty/inspection friendly :D
