Cat "test" pipe for 6.0
RoyBoy
Diesel Dork
central WI
Does anyone make a test pipe for the stock exhaust?
Will this drop my EGT's much?
How much louder will the exhaust be?
DPPI sells one, click their link in our advertisers links section you'll find it.
Wood County Tx
noticably deeper and more pronounced,
plus mpg goes up 1-2.
I can hear now a bit more turbine whistle but its not offensive to me anyway:D
Mark Craig
Advertising Sponsor
Franklin, Tn
royfordguy,
Yes 95 Stroker is right! We have the AFE pipe that bolts right on and can be swapped in and out as needed etc.
Mark @ DPPI
triplethreat
Hubert, NC
Mark Craig said:
royfordguy,
Mark @ DPPI
Mark I could only find one on your site that was a 4" he is asking for a 3.5" for his stock exhaust. am I missing something??
Dan
CSIPSD
Bend, OR
Just save some money and gut the dang thing... Takes 10 minutes and you will never worry again...
I should have also shared w/ you that i have 1st hand experiance of
using an MBRP cat test/delete pipe on a STOCK exhaust system ('04 crewcab)
the owner had factory exhaust from the turbo to the CAT...we removed
the factory cat & installed the MBRP test pipe w/OUT any modifications
to ANY of the plumbing...(mbrp OR factory)
triplethreat
Hubert, NC
Does anyone know if anybody else carries a cat delete that will fit on a stock system. I just cancelled my order from DPPI since they are on backorder for 3-4 weeks and was hoping i could find someone else that sells them.
Dan
