cleaned the EGR valve
caissiel
Laurent
Rogersville NB
I removed my EGR valve today and it was very clean, was surprised about how clean the passage was also, it looks as if it was not removed before, but I cleaned the dust away and put it in again. It was a bit difficult to remove but after a few wiggles it came right off. Not much room there to realy get a good grip. I have 70,000 miles on my truck, must have been well driven hard befor I bought it .
turn it 1/4 turn, loop some wire thru the bolt holes & then use a pry bar
(screw driver, bar, broom stick) and leverage straight up...itll pop right out.
when you re-install it you should replace the o-rings & the silver/graphite
base gasket (retail for the gasket kit is about $7.50)
Ford part number 3C3Z-9P455-AB
Lynden-Jeff
Landscaper
Hamilton, Ontario
Cleaned mine out today aswell, thought it was casuing another issue but it turns out not. There was so much carbon build up, I was amazed. Looks like this is going to be a normal routine.
Cheers
Jeff
ckamp52
ckamp52
italy,tx and stephenville
i cleaned mine a few weeks ago before a trip to georgia and it was fine until about halfway home. it stareted acting up and so i just unplugged it for the rest of the trip it ran fine. now it has started acting up maybe oncea a day and i dont understand because it is still unplugged guess i need to get it checked out might wait and order AE before i do anything-thanks ck
