Code 27 LED help, which bulb???
Red Monkey
Alabaster, AL
Ok, I've been getting the dreaded 'code 27' flashing airbag light for long enough, so, I decided to do the LED fix. I found some great threads on how to do the fix, it sounded simple enough so off to Radio Shack I went to get an LED bulb. Well, wouldn't you know, I couldn't find a 12 volt LED bulb, they were all 1.5, 2.2 or 3.something volts... Do any of you guys have any suggestions as to which bulb to use, I have a 12volt electrical system so I assumed I would uase a 12v bulb. None of the threads I've read on this suggested a bulb voltage.
bbressler
Happy, TX
276085 is a 12 v led bulb, but I'm not familiar with the fix you're trying, so I can't say if it'll work. (I do have a couple in my truck attached to 12 v power, though).
Red Monkey
Alabaster, AL
Digital Oxygen
Got Boost?
Rockies
Forbidden
You don't have permission to access /forums/617589-flashing-air-bag-light-lamp-fault-code-27-a.html on this server.
Additionally, a 403 Forbidden error was encountered while trying to use an ErrorDocument to handle the request.
Those links don't work. Did you break the links as well? :D
