Question Codes
Today I got a code PO341 looked it up but I'm stumped. WIKI P0341 Camshaft Position Sensor Circuit Range/Performance, but you go deeper it says P0341: Electrical noise detected, check wire routing and grounds. So witch is it?
Cam sensor failure on the 6.0 is unheard of.... check your wiring and grounds as it says.
no-red 6 0
Senioritis
southmetro MN
according to what i found:
p0341: camshaft position sensor A circuit/range/performance (bank 1 or single sensor)
cmp signal intermittent
poor connection, defective sensor, electrical noise
MONSTERPLOW
Cloud Booster 500HP
I 95n.b. 1/10 Keystone State
new tuner or tunes ??? could be throwing phantom codes...... happens frequently from what my tech says ... ....erase em see what happens :dunno
Milly333
