Question Control Module Location
Smoky
Mississippi State
Where is the Control Module located on a 2004 CC 6.0L?
I replaced the battery in my keyless entry keypad and I need the code to reset the keypad. The radio has been replaced so it is not on the bottom of the radio. I have never know the code as the previous owner did not supply to the dealer when he traded it in. I have carried it to the dealer right after I bought the truck and they could not get the code for me using the scanner.
This keypad is not original as it is dated in 2006 when I opened it to replace the battery. It may be aftermarket and not FORD but it has no manufacturers markings that I can find.
Supposedly the control module has the key code printed on a label on it.
KRISTOLSON
Thief River Falls, MN
On mine I pulled the flip down storage box that is right under where the factory brake controller would be all the way out, then I took a flashlight and could just barely see the module and was able to make out the code. Once I got that door removed, I had to look up, slightly toward the firewall, and slightly to the passenger side. I had to push some wires out of the way IIRC.
willie "D"
Oak harbor
Mine and a friends is center dash under radio. can be seen from driverside floorboard.
willie "D"
Oak harbor
Let's start over, forget about the radio.(to far up the dash) Looking at the dash i would say the module is attached below the heating controls. You'll need a flash light and a extending inspection mirror with pivoting head, worm :lmao yourself onto the driver side floor board, look up under center dash, above the heating ducts attached to the firewall is a black module. orientate flash light and mirror so you can see the front of that module. on mine and my friends 250 there's a white sticker with our entry code on it. i found it's helpful to have a friend standing by to right down the code and even try it before you get out of the floorboard.;tu
rukirok
