cooling of for the summer
I'm liking your signature, chp. The google ads have about ruined a few of our "neighbors".
Yeah it's a shame how those once friendly places used to be before they went to "For-Profit" status:doh:
SDD will remain google ad free with no premium membership payment($$$) required to make some of the ads go away.
On subject I backwash out the front condenser for it usually gets clogged with bugs,dirt and debris from the prior cooling year. :sweet
georgetown texas
Flushing with water will add non condenseables to the system. Using the proper flushing fluid and make sure you get a good vacuum on it to get rid of all the moisture in the system.
silvervic99stang
tomball tx
fixed my a/c problem went to the ford house and bought the bolt that goes on the compressor and clutch and made some spacers out of washers to get the right air gap and it worked woooohoooo i guess it just got loose and fell off dont know why
bears4x4
grease monkey
katy texas
the evacuation pump and 134a gauges are FREE for the loaning from autozone.
while youre there, i'd replace the fan/drive belt.
and you SHOULD replacethe orifice tube in the system (they tend to catch the debris
and they are critical to the balance & flow in the system)...the orifice tube is anywhere from 1.99
to 49 bucks (severe service) @ autozone.
the single alternator belt is 56 bucks.
its recommended that you flush the system (to wash any debris out)...
do NOT use water...there are special flush chemicals that should be used,
mixing the wrong fluids or oils can cause SPARKING inside the cooling system !
the a/c system Capacity without auxiliary climate control is 42.0 oz
of 134a & PAG Oil the new compressor should come w/ info that
tells you how much PAG oil is required.
if you have an auxiliary climate control (excursion rear a/c) then the
capacity is 68.0 oz
check your upper and lower coolant hoses while youre there (the lower
hose inparticular rubs against the steering control arm and can rub
a good size slit in the lower hose...even when you have the ford nylon
webbing over the hose)...ask me how i know ;)
fwiw if you lower radiator hose is rubbed, replace it and use the old hose to
wrap around the new one for some added "rub" protection. -->
im glad i saw this, this will fix me up just right, using the old hose to help the new its like a dyi duaaaa :) i cant belive i didnt think of this
