May 22, 2012 #1 T TexDiesel SDD Junior Member Joined Jul 29, 2011 Messages 13 Reaction score 0 Location Dickinson TX 7.3 have to crank along time before it will start could it be hpop going out it has 300000 miles. Any ideas?
May 22, 2012 #2 DaveBen SDD Senior Member Joined May 31, 2005 Messages 9,641 Reaction score 84 Location Ukiah, California HPOP is gone. You have a LOT of miles so it would not surprise me that it is HPOP time. Dave
May 22, 2012 #3 dpantazis #12 Joined Nov 8, 2005 Messages 1,854 Reaction score 1 Location under the cheddar curtain It could be anything. Seek professional diagnosis. How is you oil level otherwise. Low pressure oil pump feeds the hpop. There is s check valve in there too. Could be as simple as a $10 part.
May 23, 2012 #4 iracemine black and tan Joined Dec 10, 2006 Messages 958 Reaction score 0 Location Cheese Curtain dieing batteries, glow plugs, gpr, corroded cables, weak starter, ect....
May 23, 2012 #5 B BIG JOE Full Access Member Joined Apr 6, 2005 Messages 5,423 Reaction score 55 Location CenCal iracemine said: dieing batteries, glow plugs, gpr, corroded cables, weak starter, ect.... Click to expand... What he said.. would be the things to check & eliminate first ? But.. it takes 500 psi HPOP pressure, minimum, to pop the injectors @ start-up. A good Scanner would detect that. (ICP pressure, while cranking) Joe Last edited: May 23, 2012
