97powerstroker
i hooked up a scanner and did the cylinder contribution test and it pulled this code p1184-eot sensor circuit performance. now manuals description is, eot less then 68* or above 242* during koer cylinder contribution test. truck was at operating temp when i did the test.manaul also states that if pcm thinks its gettin a faulty reading,it will ignore the eot and assume an eot of -4* degrees for starting and a temp of 212* degrees for running conditions,but no check engine light,im wondering if this could be why i get so much smoke in the mornings?if the sensor is bad ofcourse,im going to do a couple of tests on it tomorrow to confirm it.
