96P_Stroke4x4
well, i got lucky and was able to pick up and install a dana 60 over the weekend.
Thanks Rich! (94f450sd)
it came out of a '94 f-350 dually dump truck with a whopping 68,000 miles on it
i got everything with it, sway bar, trac bar, and all the brackets. i installed f-350 springs in the summer, so i didn't need them. the only thing i have to do is replace the steering linkage, finish drilling and bolting up the sway bar brackets and bolt on the driveshaft, once i get the bolts out of the yolk
. surprisingly, the truck sits level now, so i won't be raising the rear end. i ended up with all new rotors, pads, calipers, u-bolts, and brake lines. while getting the brakes worked on, i changed out the master cylinder with a reman because i started to see signs of failure. i have to thank lil joe (wreckaboy1) for his help with the installation.
here's a few pics
here's a few pics
