Question Diagnostic code PO236
dbcooper5140
Milton, FL
I have an Edge Revolution that I use on my 1996 F350 7.3 turbo diesel. I did a diagnostic today and got a PO236 which has something to do with my turbo sensor. Does anyone know what I would need to do to correct and can I fix it myself? Thanks DB
Frankenstien
Frankestien
South Prairie Wa.
This is a common code you will see with a programmer or chip. if it does not set the SES light I would not concern myself with it.
"0236* MAP Turbo boost sensor A ckt performance Uses Inferred MAP signal Restricted inlet/exhaust/supply hose, "
