Don't leave me stranded...
02EX_PSD
Not as Junior of a Member
NW San Antonio, TX area
I keep talking to my truck but it ain't listening!
It has started to stumble under light acceleration lately but seems okay on the highway. There is no check engine light on. Does this sound like a CPS issue or fuel delivery issue to you? Maybe something else?
Most of the highways around here are under construction and there is no shoulders to pull over on if she croaks......Thanks
Keller, TX
CPS is inexpensive, so go ahead and replace it and see. Mine didn't just fail like many others...it was intermittent. So, that could be the culprit.:2c
02EX_PSD
I will definitly restock the glove box supply cabinet!
Oh, by the way, it started acting up again. I replaced the fuel filter just to eliminate that issue. Any other ideas??
Perhaps debris clogging the fuel tank pickup screen or the mixer screens in the tank are clogged? Air in the lines? Fuel Pressure not enough from the fuel pump?
Too many variables,could be a sensor up in the engine area?
Hook a code scanner up to pick up any DTC's?
hammer450r
NJ
Might be the dr pepper can stuck in the exhaust pipe
