Door Controls going out
RenoF250
DungBeetle
California
My passenger side door has been acting up. First the locks were taking a few hit to unlock and now the window is intermittant. Is this just coincidence or could I have a ground going bad or something?
You might want to pull the door panel and inspect the wire harness plugs for a loose connection wire.
When the problems arise is it from the drivers side control panel switches or from both(L&R) door control panel switches?
I know the power lock actuators do go bad and it's right about this point when it takes 2-3(or more) times hitting the button for them to lock/unlock.
Bill
RenoF250
DungBeetle
California
Bill
The window is from the drivers side controls and I think it has done it from the passenger side controls also. The locks are from the drivers side and the remote. I am thinking it may be coincidence and I need lock actuators and a window relay.
Chewman
Michigan
I too am having the passenger door lock actuator not unlocking or locking. ANyone know what one of htese is going for?
Are there any other syndroms that this couldbe a sign of?
Possibly switches have gummed up spilled coffee,soda,etc thats interfering with the continuity of the electrical system.
Worst case scenario is the GEM unit that everything runs thru.
You may have to tear into the switch panels and do a swap between right and left to see if the problems remain the same.
bad_bad_bubba
The Colony, Texas
Yeah my driver door has problems sometimes. Usually happens if I just run out to the truck for something. If I have had the truck running no problem on the fisrt try. If I hit the wrong button on the remote it doesnt always lock right back up. I need to replace the accutor on mine.
Dieselmeister
Havascrew Arizona
Depending on how much you want to spend you can fix it fairly cheaply...
On my truck all the locks stopped working, except the drivers door.. I was able to purchase so lock actuators from a place that sells alarms & other kits... they were like $4 or $5 each...
All you do is place them inline with the factory locks... you splice into the wires and your done... it took me like 30 minutes per door to fix them... I did that about 7-8 months ago and they are still going strong... The three actuators and the little blue wire splicers cost me a total of about $20...
You can't tell anything is different and even if you were to look behind the panel it would be hard to tell that something was different.
For me there was no option of going with new factory actuators... they are way over priced...
gquad41
